re: pARKING pOSITION.
"Parking Brake
A habit that one needs to get used to is always to set the parking brake when parking, especially on hills. Unlike automatics, there is no locked parking position with a manual transmission, only the internal friction of the non-running motor. Make sure you set the parking brake first and let up on the brakes to make sure it is engaged fully, then leave the gearshift in reverse or 1st."
http://www.standardshift.com/faq.html
very similar here:
"Shutting Down And Parking The Car
Stop and park the car. Hold the clutch on the floor and the foot brake.
Set the parking brake. It is very important to always leave a manual shift car with the parking brake engaged. There is no "park" in a standard gearshift. If you don't set the parking brake, there will be nothing holding the car in one place.
Switch off the engine.
Release the clutch.
Release the foot brake. It's important to release the foot brake last, especially if you're parking the car on a hill.
Leave the car in 1st. gear. If you leave the car in gear, it acts like "park" in an automatic car. The engine becomes engaged to the wheels and the car can not move. You should always use the parking brake anyway, even if you do leave the car in gear. Don't leave the car in neutral unless the road surface is level. On an incline leave the car in 1st. gear for uphills, and reverse gear for downhills. Don't leave the car in any other gear. Remember to place the car in neutral when starting the engine."
http://cssdrivertraining.com/manualprimer.htm
another site... similar again:
Remember the parking brake
"It is important to note that the emergency brake is very important when parking a stick shift car, because there exists no "park" gear to keep the car from rolling. Some rely only on the pull-up emergency brake, usually sufficient in most situations. But for extra safety, leave the car in gear AND use the emergency brake."
http://www2.stlu.com/static_html/le...t.asp?ugid=K3PALTEQS4S79UQ&pid=556&navbar=yes
