1 - 15 of 15 Posts
[quote author=Alec Trevelyan link=topic=136099.msg2931261#msg2931261 date=1234425242]
Since I'm already pimping this in 3 other threads, why not one more? ;)
Ug i wish i could paint that good :(
[quote author=gar187er link=topic=136099.msg2934666#msg2934666 date=1234550295]
take off the pieces, sand, prime, paint, clear coat.....
That's pretty much it. There are several diy interior painting threads.
If you have an 07, don't make the same mistake I did. The panels on the steering wheel are screwed in (you have to remove steering wheel to gain access http://www.mazda3forums.com/index.php?topic=45816.0), they don't pry off like some threads say...they may pry off in models earlier than 07. The panel on the dash snaps off, not sure about the door trim.
That's it, minus the sanding, priming, and clear coat... I used Duplicolor metallic paint, which won't take a clear coat anyway (it dries semi-glossy and clear coat just runs right off this stuff) :) I did sand and prime the other interior pieces, but I like how the wheel bits came out a lot better
[quote author=nuffsaid link=topic=136099.msg2934758#msg2934758 date=1234551955]
Really? Mine's an 07 and I just pried everything off...there was a zip-tie in each side of the steering wheel that had to be cut but that was it...
[quote author=Alec Trevelyan link=topic=136099.msg2934789#msg2934789 date=1234552356]
that's interesting...I wonder what's up w/that?!
[quote author=Alec Trevelyan link=topic=136099.msg2934813#msg2934813 date=1234552652]
Maybe it's just the S models or something? Or maybe since that thread you linked is about installing cruise control, cars that come with the cruise control installed don't have screws?
that may be it, I have an i sport w/out cruise
1 - 15 of 15 Posts
