if you are to install a part on your car and the part that you installed causes something in your engine to get messed up then warrenty will NOT cover any charges. But if you have installed say an exhaust and your power steering fails for some reasone then you are still covered under warrenty. So the only thing that loses warrenty is the part that you replaced unless it is the direct cause of the malfunction. Hope this clear everything up for you.
