1 - 6 of 6 Posts
Hello,
for a 2007 model, I understand the 2.3L engine has a potential problem with filter houses cracking, and the 2.0L engine does not.
Is this correct?
How can I make sure I don't have this problem? (I don't think I have 2.3L engine but I want to double check)
Does nayone have a picture of what the 2.0L filter is supposed to look like, and where is it located in the engine bay?
I thought the conversion was for the 2.3L, no?
I'm asking about the 2.0L, does it have a standard oil filter? (the type that comes with its own metal round housing)
[quote author=WNCMazda3 link=topic=138630.msg2987427#msg2987427 date=1236779080]
Spin on filter conversion, lots of threads on this one.
lotsa threads DISCUSSING it, but there are only 2 links to the actual product, and one is down completely. There needs to be a writeup on installing this unit. Its fine to discuss it, and how to do the DIY oil changes, but there are some that might need a writeup and pics..
Here is the one I found that is still working:
http://siteground207.com/~protegeg/product_info.php?cPath=160_256&products_id=1210
I like the writeup at http://www.supercar-engineering.com/rubberducky/Mazda3/Maint/2.3L/OilC/index.html
for the pictures. In there you can see on this pic
http://www.supercar-engineering.com/rubberducky/Mazda3/Maint/2.3L/OilC/DSC00164.jpg
the cartridge housing and see the bolt where you would remove it, and replace with the product up above. should be straightforward.
EDIT: this is the closest to actual instal writeup I've seen
http://www.mazda3forums.com/index.php?topic=74254.msg1683876#msg1683876
[quote author=victor_t link=topic=138630.msg2987495#msg2987495 date=1236782792]
The 2.0L has a standard spin-on filter. The 2.3L has a cartridge filter with an aluminum housing and a plastic cap that can be cracked by negligent removal or installation.
[quote author=rpn453 link=topic=138630.msg2988639#msg2988639 date=1236813781]
The part about "negligent removal or installation" is key here. I haven't heard of anyone here who's had their filter cap spontaneously fail for no reason...but I've heard several stories about people who have had their caps fail after having a quick-lube place perform an oil change. The design of the cap isn't defective; the failures of the caps are really due to carelessness/cluelessness. If Mazda didn't have faith in the design of the cap, they wouldn't have stuck with it for the DISI (which also has a more complex oil filter housing, as there's a factory oil cooler). If you have a 2.3, take your car to a trusted mechanic or dealer, or do oil changes yourself, and you will have nothing to worry about.
1 - 6 of 6 Posts
