Hello people!
I have a Mazda CX-7 2010 with a 2.3l turbo, I had to pull the engine because the flywheel had broken teeth I put everting in the way it should be and I’m getting no spark at all, I am getting power to the coils and the coils are good, so are the spark plugs, I also make sure that the crankshaft position sensor was at the 20th tooth, and I did that with cylinder number 1 at TDC. All grounds are connected as well, there is no blown fuses I’ve checked them all. It was running before I pulled it. I’m lost on what to check now.
Sent from my iPhone using Tapatalk
