1 - 14 of 14 Posts
so I live in pa my names darian I have a silver mazda 3 sedan with options
as I spend another 45n min typing this up cus I time out -.- I hope you enjoy
ENGINE MODS:
AEM intake
corksport exhaust with test pipe
ov 93 bench tune
Damond rmm
Damond pmm
AWR 88 duro trans mount
tb ground (that's a mod right?)
Vibrant performance 4-2-1 ceramic coated headers
3inch vibrant high flow cat ceramic coated
SUSPENSION
8k 12k bc br with camber plates valved for spring rates
with adjustable front endlinks
Hotchkiss rsb
poly filled trailing arm bushings
Whiteline rear adjustable endlinks
Dominant engineering camber arms
TRANSMISSION :
twm short shifter with bushing
extender and phantom weighted knob
BRAKES:
speed 3 brake swap
dot approved techna-fit brake lines
hps pads
centric blank rotors
MISC:
08 interior swap bezels and panels
08 tail light swap
mazdaspeed3 seats n corbeau front seat
cooling panel
custom headlights blacked out with cutoff mod and painted cutoffs
interior lighting
Fog delete
cs stubby attenna
Mobil 1full synthetic 5w-30
TO DO LIST:
battery relocation
catch can setup - done
new clutch resurface flywheel (if possible)
full ground kit and big 3 -done
afr guage- not doing aorn
Oil pressure -done
tints prolly not rn
Shave wieght
Thanks, I relied I can't do a vtcs delete luckily it was on my second manifold
Discussion Starter #4
ENGINE MODS:
AEM intake
ov 93 bench tune
jbr 80 duro rmm
topspeed pmm
speed 3 cs insert
tb ground painted vc(that's a mod right?)
SUSPENSION
mazdaspeed3 rsb
new replacement bushing non poly
just moog
cs camber arms
cs front strut bar with custom setup for ingalls torque damper
TRANSMISSION :
BRAKES:
speed 3 brake swap
hps pads
MISC:
08 tail light swap
mazdaspeed3 seats
cooling panel
mtx jackhammer 12 inch with jbl 770 amp with jbl speakers
interior lighting
cs fogs
cs stubby attenna
Valvoline full synthetic 5w-30
TO DO LIST:
battery relocation
vtcs delete
catch can setup
speed 3 vc
sure tmm and pmm
plastic dip the cars white (due to the rust)
vynl door sills (rust again)
afr guage
ail pressure
spc camber arms
tint
Balance shafts delete
some other here there things. I'm proly missing some stupid things
Trying to figure how to cut weight n if I can infant delete ac
So since it's been awhile I've changed alot if things from damond motor mounts in the rear n passenger side I got ahold of d.e camber arms I went to a Hotchkiss rsb deleted fog lights took out the sub. The corksport bar is going no more torque damper, n will be updated
Discussion Starter #5
So my corbeau seats showed up today! N some how cracked my oil filter canister n went all over my shop floor after start up, the autox season over n I did really well, I got 2nd in 2 regions due to lack of events, I contacted 18 racing placed n order for 15x7.5 rota slips, currently trying to fit wilwood brakes for the speed 3 but run 300 mm rotors, will see
Discussion Starter #8
Well I guess more updated got corbeau racing seats
Ebc yellowstuff
Going back to standard brakes
Innovate oil temp n pressure guage
Whiteline adjustable rear Endlinks
AWR tmm 88 duro on its way
If anyone can find me a set of vibrant headers IL love you you in a gay way forever
Discussion Starter #9
Updated
I got my new trans mount in catch cans installed
Found a set of vibrant headers n ceramic coated them oil pressure guage is almost installed, my slips have also arrived
Did you use a sandwich plate for the oil pressure/temp sensor or did you re-use the OEM sensor location?
Discussion Starter #11
I used corksport but didn't realize the housing I bought has n external oil cooler on top n I already had the housing that I bought from mazda motorsports, I found a use cooler for 45 but if I was to do it again either get corksports or get I think it's prosport n get the right fitting to fit either the Ford focus housing or the mazda 2.0 housing because the speed 3 has a different thread size but I like the bigger filter
1 - 14 of 14 Posts
