I'm retaining my stock HU but want to add two amps one to run door speakers and one for a sub.
Do I need two Navones?
If so how would they be cabled?
You could run two LOCs if you want, but a single four-channel LOC should be just fine. I'm assuming you'll be installing your 4-channel amp and sub amp next to each other. If the 4-channel amp has passthrough audio connections, run the 4 RCAs to that amp, then just get a short RCA pair to go from the RCA output on that amp to the inputs on the sub amp.
