1 - 20 of 24 Posts
I got my car last Nov and have been reading the forum for a while.
Finally put some wheels on, and for those who say 8.5 rim with 30 sth offset won't fit our car you are WRONG!
These are Sportmax 962 18X7.5 +38 in front and 18X8.5 +35 in rear with 225/40/18 Kumho MX all arround.
It did rub in the rear at first, and the fender did cut my tires about 1-2mm deep. I rolled them with a baseball bat and it's fine now even with 3 people total weight of 400lbs and cornering hard. It didn't rub even when the traction control kicks in. So I don't think they will ever rub.
BTW my suspension is stock.
OK, here is the prove!
Not to get down on ya mate, but why did you put wider wheels in the rear, and use the same size tyre? :-S Or just why did you choose those sizes?
staggered ehh, interesting take on the wheel debate.
you also went with a fairly agressive offset, have you had your car up in the air and had a chance to inspect inside clearances? would be interested if you could somehow get a picture next time you are down there. :D
where exactly did the rear wheels rub? I always thought the wheels would rub on the inside with a wide tire, but with your offset im gonna guess it was rubbing on the lip?
There are at least 1 inch clearance inside the wheel both front and rear.
I would say you can get even bigger tires on front without rubbing, may be 235/40 since the front fenders are wider.
AND for those who ask why I went with a staggered set, I just like the look and want to be different.
Similiar to VW Golf and Jetta, they use staggered wheels on FWD. And I think it looks good in 3 too.
A good example:
As long as the tires are the same, it doesn't affect the performance except may be a little bit more understeer. But hey when you have 265hp in a FWD car, understeering is expected.
Discussion Starter · #7 ·
[quote author=zoom_craigy_zoom link=topic=69214.msg1200216#msg1200216 date=1171167094]
You rolled your fenders with a baseball bat? I don't know the proper procedure for doing this... but I'm guessing that isn't normal?!
Well, you can rent a fender rolling for $40-50 bucks for 3 days, or you can have a shop roll it for you for $80 a side.
Or you can just use a breaker bar or a small baseball bat and a heat gun to roll it, it gets the job done if you know what you are doing. I rolled my Corolla AE86 to fit 0 offset rims, my friend's Miata and Jetta and they all look great.
[quote author=2007MS3 link=topic=69214.msg1200233#msg1200233 date=1171167715]
Interesting. I wasn't bashing the way you were doing it, I had just never heard of that before. Do you have any pics of the final outcome? I'd be interested in seeing it.
[quote author=zoom_craigy_zoom link=topic=69214.msg1200239#msg1200239 date=1171167867]
I don't have pics of it, but I can tell you it doesn't look as smooth as those fenders rolled by fender roller.
However, you won't notice unless you put your hand down there to feel it.
[quote author=2007MS3 link=topic=69214.msg1200246#msg1200246 date=1171168064]
In which case, nobody will... so you are all set! Cool man...
I'll let you get back on topic now... sorry for that :p
Wow, a baseball bat! they have been rolling fenders with them since the 50's Old School, right there. Wheels look nice!
Not feeling those rims at all. Makes it look like you got 16s on there. Just my opinion tho. And staggered look...hmm. okkk.
I'm not feeling the rims either. I personaly do not like thick 5 stars. The lip on the rims is a too thick also. It makes the rims look cheap IMO. I do like the idea of wide rims in the back and thinner rims in the front although it does seem a little odd on FWD cars.
I did the same in my z. It is a must when you put in coilovers and lower your car over 3". bat doesn't work so good on fiberglass fenders :)
I saw a pretty nice RSX with staggered wheels in a tuner mag. But it was staggered larger width in front and small in back so the ass-end would slide out easier in corners.
1 - 20 of 24 Posts
