I'm not quite sure if this should go in audio or interior modifications... it's a little of both.
I finally received my Auxmod in the mail today (thank you, Sylfex) and would recommend doing business with these folks as they are really easy to work with and make a quality product.
I wanted to be able to quickly plug in my iPod in a convenient yet hidden location to keep it out of sight/sun. I bought a 3.5mm male/male cable from Radioshack, along with a gold-plated coupler, totaling to around $10.00.
Now, I will show you what I did with them:
I took a large washer which already had a small hole (obviously) in it. I enlarged that hole using a 3/8" bit, to fit the coupler.
Then, I firmly tapped the end of the coupler into the 3/8" hole (it is a VERY tight fit) until about 3mm stuck out the other side of the washer.
There, now my coupler has a flange on it, making it perfect for this install. Where you decide to put this is up to you, but below, you will see how I did it.
I removed the center console pieces, and drilled a 3/8" hole just above my cigarette lighter (the cigarette lighter is not OEM, I did that earlier). Then, put a little bit if liquid nails on the top side of the washer, and plug it into the hole. This is what it looks like:
Now, I can keep my iPod inside the center console, it can charge while I drive, and can also play through my speakers with no more FM modulator (YES!!). All thanks to this wonderful little invention made by Sylfex.
This is what it looks like with the console lid open looking down:
