Hi all, it might be too early to ask about this, but I'm wondering if anyone knows about the camber curve in the front?
Some MacPherson strut cars are designed in such a way that they "gain" camber through the suspension travel, meaning you have to run a ton of negative camber and/or very stiff spring rates in the front or your camber will increase (bad) under hard corner loads. I
t's something that us RSX Type S kids have to deal with on our cars... :?...it's especially a factor if you lower the car too much. I'm kinda interested in the MS3 and figure Mazda normally does suspension very well, but I was a little disappointed to see that it doesn't have double wishbones (which usually have a great camber curve) in front. From here it appears they just added stiffer springs and bars and relocated the tie rod link to stiffen things up well, reduce ride height and eliminate bump steer. Which I've already done on my car as well.
I'm sure the MS3 handles great out of the box, but I'm specifically interested in this aspect in terms of track performance potential.
