2007 Mazda 3 2.0L Automatic. Car idles and drives rough under load. No CEL codes. Feels like a vacuum leak, but no loose or broken vacuum lines.
Parts replaced or cleaned within past 6 months:
OEM Iridium spark plugs
Purge Solenoid Valve
Passenger side and rear mounts
Throttle Body removed and cleaned
MAF sensor cleaned
Air filter and Oil + filter change
Serpentine belt
Transmission flush and fill: First time and it was at 80,000 miles. The mechanic used Wolf's Head Universal ATF. I was worried about it being machine flushed as opposed to drain and fill, but it's been 3 months and no issues. Made a noticeable difference in smoother shifting.
The purge solenoid fixed the starting issue after re-fueling, but didn't seem to effect roughness. My suspicion is either:
Drivers side mount
o2 Sensor
Intake gasket leak
Comments and suggestions please
MAF sensor cleaned
Serpentine belt
Drivers side mount
o2 Sensor
Intake gasket leak
