1 - 11 of 11 Posts
[quote author=DeToX link=topic=134369.msg2888680#msg2888680 date=1232856467]
hatchback yes. sedan i dont think so
They work for both... Why do you reply if you don't know?
To OP, the spring and shocks from any 3 (sedan, hatch, speed 3) will fit your sedan. However, the rear sway bar for 04-06 is different than the 07+ but you can get it to fit. You can find out about the modification that is needed to fit the rear sway bar by searching
[quote author=justint5387 link=topic=134369.msg2888942#msg2888942 date=1232870859][quote author=DeToX link=topic=134369.msg2888680#msg2888680 date=1232856467]
The speed 3 springs are much stiffer and have a sportier feel than the N/A 3 springs. I have them on my sedan and love them. They're a great and relatively cheap mod. Lots of members sell them on here for around $100 a set.
[quote author=pinkcheese link=topic=134369.msg2889110#msg2889110 date=1232896924]
i shouldn't have a problem then with a 09 sedan.
It will be fine....
EDIT: I forgot one thing, the endlink bolt on the speed 3 is bigger. So you will need to find a sleeve that will fit inside the gap or you can get the speed 3 endlinks.
i was lookin at the cobb rear sway. so i wouldnt have an issue with my 05 sedan?
[quote author=NW08S link=topic=134369.msg2910749#msg2910749 date=1233720008]
[quote author=jesusm3 link=topic=134369.msg2909921#msg2909921 date=1233698405]
Different endlinks
is there anyway i can swap out the endlinks? ive never really dealt with suspension. i have a pretty good descent knowledge on motors and turbos but when it comes to suspension i know fair amount. i am not a noob but i could use some help here
[quote author=jesusm3 link=topic=134369.msg2911672#msg2911672 date=1233765188]
Different endlinks
Yes, you can put in a ms3 end links.
1 - 11 of 11 Posts
