hey nearsite,
I was thinking the exact same thing. I've concluded dealerships and shops have incentives (profit), and the engineers at Mazda probably don't (not the same incentives, anyway). I would go with the engineers : P
Recently I went to Hayward Mazda to ask about their 30k service (and to buy an air filter), and the service center guy instantly gave me a "deal" for $450 instead of the regular $600 (shady, IMO). I've typed the list they gave me verbatim. (wasn't on their website, and I figured I'd do the Mazda community a small service :nsmile
Also, he said all that would take about 2 hours - a little fast, I thought. They do have the tools, experience, and manpower, so mayyybe they go through each one with quality?
It was funny because I mentioned my car felt a bit sluggish lately, and miraculously he knew i needed their injector cleaning service :whistle2: . I concluded he was full of it, although the injector service does look like a better alternative than fuel additives. But in the bigger picture, 30k miles and the fuel injectors need cleaning? I didn't think so..
By the way..has any of you ever been to Hayward Mazda? Did you get the same feeling as I did, where you think they're trying to rip you off the moment you step foot into their dealership?
Hayward Mazda
25891 Mission Blvd
Hayward, CA 94541
510-865-2000
Change engine oil, filter, and replace drain plug washer.
Inspect for fluid leaks
Check wiper and washer operation
Inspect and record amount of rear and front brakes remaining ___________mm
Inspect and record amount of rear brakes remaining __________mm
Adjust parking brake and lubricate cables
Inspect exhaust system
Inspect suspension system and steering complementary. Check control arm pivot bolts.
Check wheel bearings for play
Check constant veolocity joints & boots ______noisy_____torn_____
Check and top off all fluids (including power steering, brake, clutch, transmission, washer, and battery.
Check hoses.
Check and adjust timing
Replace air filters
Replace spark plugs (60k only)
Replace fuel filter, if applicable.
Replace coolant
Replace transmission fluid
flush brake system
lube all doors hood and trunk hinges
check and set tire pressures including spare to factory recommendation
rotate and balance tires front and back
check throttle cable free-play
road test vehicle for performance
complimentary mazda full circle report card
compl
ementary car wash.
