1 - 20 of 26 Posts
I have a 04 mazda 3 sedan and whenever I fill it up i have to press the gas to get it started. I have to keep pressing the gas to keep it going for about 15 seconds or it will stall. Other than refueling the car starts and runs fine. If you have any suggesting or idea that would be great. thanks
Banned
Have you thought about fuel injector cleaner? Lucas brand is the best.
Also, there should be no reason that you have to give it gas to start. Unless something is clogged somewhere... Thats strange. Good luck!
Yes i do turn the gas cap until it clicks a few times. Also I've used the injector cleaner but it doesn't seem to help. Is there anyway that the filter may be clogged in the tank?
fuel vapor purge valve solenoid is stuck open. Same thing happened to my 3. At the time mine went out they were on backorder but you may be able to get one now. Somewhere is information on finding and testing the valve, if you can not find it I will try and post a picture and location and the test I did on it. ( I blew threw it BTW) I just unhooked mine and plugged the port going into the solenoid and left the tank vent open. If you run with the valve stuck open it may throw a code since it will run lean, it causes a vacuum leak.
That sounds like that's exactly what i have wrong. How much are the purge solenoid valve? Is that the solenoid that has the blue and red connections by the brake fluid resevour? What year is your car? I wonder if this is a common problem with the 04. Thanks for your insight.
10 INSPECT PURGE SOLENOID VALVE STUCK OPEN
• Turn ignition switch to off.
• Disconnect both hoses from purge solenoid valve.
• Blow air through purge solenoid valve.
• Does air blow through? Yes Replace purge solenoid valve
Did you blow in both directions? Hmmm, does your car start hard after every fill up? Maybe it is intermittent.
Try this then. Take the hose that feeds the sensor off and plug the sensor with a cap of some sort but leave the line coming from the firewall open so it can vent. See if it is still hard to start after fueling.
No check engine light?
[quote author=nixmak link=topic=135450.msg2939074#msg2939074 date=1234749143]
I will give that a shot and we shall see. Thanks for the help.
Not a problem, just hope we figure it out without costing you a trip to the dealer.
Discussion Starter · #19 ·
i plugged it up and refueled and it started right up!!!! So that means it's either the PSV stuck open or there is a short for the switch.. correct? How long can i run it like this? THanks for your help!!
[quote author=nixmak link=topic=135450.msg2940190#msg2940190 date=1234802057]
Well, I would fix it as soon as you could but I have ran mine for about a year with it blocked off and it has not caused any problems. As long as the sensor is plugged so you will not have a vacuum leak you should be okay. If you leave it open it will cause a lean condition that would lead to problems.
Jason
EDIT: Forgot to answer one of your questions.
Even though the sensor passed the test you gave it I would say it is bad as this is such a common problem with our cars. You could look at the harness for signs of rubbing/wear and look at your connection for corrosion but changing the sensor and clearing the code should make you golden.
1 - 20 of 26 Posts
