1 - 11 of 11 Posts
Hi all,
I'll try to explain best I can I have a 2010 mazda 3,the panel randomly says drivers side front door open and same with passenger side and turns the inside lights on,so I have turned inside lights off,because it now sends battery flat with interior lights off,also I we lock the drivers side door to activate the central locking the problem doesn't happen and the car battery is new as well , cheers for any info and car is accident free
It’s more likely your door lock actuator that is bad, a very common problem for these cars. So common that my local dealership stocks replacements in their parts department, no ordering from the warehouse necessary.
What both of them
The problem is I don't know if there is a way to test them. Since the driver door gets used the most usually the money is on replacing that side first, and if the problem persists then it might be the passenger side. I haven't heard of the rear door actuators causing as much trouble but I guess they could.
1 - 11 of 11 Posts
