[quote author=GT1 link=topic=134342.msg2890691#msg2890691 date=1232957347]
[quote author=qwerty4550 link=topic=134342.msg2889845#msg2889845 date=1232932296]
[quote author=the_caruch link=topic=134342.msg2889767#msg2889767 date=1232927931]
[quote author=qwerty4550 link=topic=134342.msg2889411#msg2889411 date=1232912075]
So what are acceptable ltft at idle and WOT? I am pretty sure my idle is around -6%, but not sure about WOT. I will do a datalog and check the next chance I get.
0% for WOT is what you want, but without a tuner it's probably going to be +/-2-4%
Being a percent or 2 rich isn't too bad at WOT. You definitely don't want to be too lean at WOT though.
So when you are in the negative you are running rich, and when you are in the positive you are running lean, correct?
No. LTFT does not tell you anything about the actual fuel mixture (i.e. running lean/rich).
Rather, it is the amount of correction applied by the ECU in order to achieve the target fuel mixture for the current conditions.
So at WOT, if you have a tune you should be very close to 0 correct? However, without a tune (me) what are acceptable numbers? Also, what is the difference between STFT (short-term fuel trims?) & LTFT (long-term fuel trims)? Does LTFT avg every value it has received per cycle, while STFT just gives the actual value at that point (- refresh times)? Sorry for all of the noob questions, but I would like to know what I am actually reading with my DH :lol: .
Also, I know this is off-topic, but is there a way to log something on the DH to show if I need to tighten or loosen the screw on my BOV/BPV? I would rather use values over just listening with my ears.
