1 - 8 of 8 Posts
I keep on reading threads and i am all confused
let's say i have a 2006 sedan GS
i want to keep the headunit's lcd
but not the head unit
Since the lcd is not attached to the unit, it is possible
but do i need to keep the headunit
or all i have to do is plug a cable into the lcd
and it shall retain per instance the mileage to empty + the temperature
thanks guys
I can confirm that you do not need the factory HU for the LCD to work in 2006 or newer models. You only need the factory HU if you need to reset the clock display (to correct the time).
[quote author=fnguy link=topic=70736.msg1239416#msg1239416 date=1172696588]
problem is i cannot pm anyone
i don't know why
the option isnt there
you need a minimum number of posts before you can PM anyone. Try now...
not sure...check the FAQ's in this section
1 - 8 of 8 Posts
