1 - 6 of 6 Posts
shebly top of the ling alarm system.....work great....but i have to go back monday to work on bugs on the factory alarms.....also have a beef up sound system i always wanted....make my ride that much more sweet to drive...!!!
ask your installer what wiring diagram he used.
do our cars match the regular 3 for wiring codes, are we like the cx-7?
this is the mz3 diagram
12volts red (30A), black/red (30A) + ignition harness
Starter gray/black + ignition harness
Second Starter N/A
Ignition green/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory pink/yellow + ignition harness
Second Accessory yellow + ignition harness
Keysense red/black + ignition harness
Power Lock green/red -
driver kick, door
harness
Notes: Lock is negative trigger thru an 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use
relays.
Power Unlock same as power lock wire
Lock Motor yellow/black 5wi
driver kick, door
harness
Unlock Motor white/black 5wi
driver kick, door
harness
Parking Lights+ orange/white (L), orange (R) +
passenger kick,
harness to rear
Parking Lights- black/white - headlight switch
Hazards black/orange - hazard switch
Turn Signal(L) blue +
passenger kick,
harness to rear
Turn Signal(R) blue/red +
passenger kick,
harness to rear
Reverse Light green/orange or green/black +
passenger kick,
harness to rear
Door Trigger see notes -
passenger kick,
harness to rear
Notes: The LF door is black/yellow, the RF door is black/blue, the LR door is black/orange, and the RR door is
black/green. Use all four wires and diode isolate each. These wires are also found at the Passenger Junction
Box behind the glove box.
These wires may rest at ground with the doors closed and go to an open circuit when the doors are opened.
Dome Supervision black/blue to black/red -
passenger kick,
harness to rear
Trunk/Hatch Pin black/red or black/blue -
passenger kick or light
in trunk
Hood Pin black/yellow - hood pin switch
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm black/blue -
driver kick, door
harness
Notes: Meter this wire while turning the key in the driver door key cylinder.
This wire may also lock the doors.
Factory Alarm Disarm black/white -
driver kick, door
harness
This wire may also unlock the doors.
Disarm No Unlock
Tachometer NOT green/stripe ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire red/white + brake pedal switch
Parking Brake black/lt. green - parking brake switch
Horn Trigger black - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module:
Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556UW
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Standard on all models. When using the 1100X, a software change to 1100FM is needed.
Interface Module:
Category:
Door Lock Interface
Required:
Yes
Type:
Multiplex
Part #: 456LW
Notes:
Smart Starter Kill Relays: Not Available
this is the cx-7
Mike M2 said:
12volts red (40A), red (40A) + ignition harness
Starter gray/red + ignition harness
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Keysense red/black or brown/green + ign harn or BCM, 24 pin plug, pin 3C
Notes: The BCM (Body Control Module) is high in the driver kick.
Power Lock green/red to black/blue - dr kick or BCM, 30 pin plug, pin 5M
Notes: Lock is negative trigger thru a 1000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Lock Motor yellow/black 5wi dr kick or BCM, 6 pin plug, pin 6E
Unlock Motor white/red to white/black 5wi dr kick or BCM, 6 pin plug, pin 6C
Parking Lights+ red/blue + driver kick, harness to rear
Parking Lights- black/red - headlight switch, pin L
Hazards black/orange - switch or BCM, 24 pin plug, pin 3J
Turn Signal(L) blue + dr kick or BCM, 30 pin plug, pin 5R
Turn Signal(R) blue/red + dr kick or BCM, 30 pin plug, pin 5O
Reverse Light green/orange + driver kick, harness to rear
Door Trigger see notes - BCM, 30 pin plug
Notes: The LF door is black/yellow in pin 5Y. The RF door is black/blue in pin 5V. The LR door is black/orange in pin 5S. The RR door is black/green in pin 5T. Use all four wires and diode isolate each.
Dome Supervision black/blue - dr kick or BCM, 6 pin plug, pin 6B
Trunk/Hatch Pin black/red - dr kick or BCM, 30 pin plug, pin 5P
Hood Pin black/yellow - pin sw or BCM, 16 pin plug, pin 1A
Factory Alarm Arm black/white - dr kick or BCM, 30 pin plug, pin 5A
Arm is negative trigger thru a 1000 ohm resistor. Disarm is a straight negative trigger. MUST use relays.
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock
Tachometer green/stripe ac any fuel injector
Notes: Can also go to any ignition coil and use the wire that is NOT green or black/blue.
Wait to start N/A
Brake Wire red/white + brake pedal switch or driver kick
Parking Brake black/red - switch or BCM, 16 pin plug, pin 1C
Horn Trigger black - switch or BCM, 24 pin plug, pin 3H
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
they are a bit different so im sure a few of us would love to know which one to go with.
damn...u scared me with that reply...i have no clue....thats why i have them did the work for me....lol
u can give them a call soundinnovations
any update on the 'bugs' ?
Discussion Starter #6
about $650....didnt get a chance to go back for the factory alarm yet....busy with work
1 - 6 of 6 Posts
