Re: MAF after a curve on an incorrect diameter pipe: a HUGE no-no!
[quote author=stretch link=topic=70133.msg1251416#msg1251416 date=1173183447]
Yikes! Somebody measure their fuel trims with this intake.
Mark my words: this intake is a mis-engineered piece of crap. You might wonder why I'm bitter, and it's because Mazda puts their name on these ho-hum aftermarket parts. It's a disgrace. The Mazdaspeed intake for the Mazda6 was just a rebadged AEM intake that Mazda marked up for more money, and it too threw a CEL.
Those who do run ECU tuners may find their engine detonating or worse, since the MAF, which the ECU relies on for fuel metering, won't know what the hell it's reporting....
However, I'd strongly recommend owners instead get an intake like Custom Performance Engineering's, since it keeps your MAF accurate while still alleviating the pressure drop, so it'll be balls-on accurate with piggybacks and ECU reflashes down the road. It's the proper way to tune, with no parts stepping on one another's heels. But perhaps most importantly, you won't have the inconsistent rise of MAF voltage- the CPE intake keeps this sensor linear and reliable. If you don't want CPE's intake, given the current market options, stay stock and see if another decent design hits the market.
So that's a hardcore post - lots of info.
Evidence - NONE!
Let me ask you this.
Did CPE have a sensor in event cranny/bolt/corner of their car ?
Did CPE have detailed/ECU data to look over after a run ?
How many hours/$$$ did CPE spend on developing that intake ?
how many hours did CPE spend on testing that intake in variable conditions. Pushing the car - even breaking it. ?
This car is "NEW". The ECU on this car is way smarter....no one really knows what its doing. Not even COBB. (sure, they're trying to figure it out) You can reverse engineer only to a certain extent.
What if I told you it measures the octane levels in your gas to control boost ?. Oh look, one new thing to add to your equation.
So now, do you have all these little details/inputs upon which the ECU processes ? NO
one final question: the CPE intake is 3" and the Mazdaspeed instake is 2.5"
Surely Mazda could have release a 3" intake, but they had data/evidence/test results...to say otherwise. Data that proved that maybe a 3" intake will cause problems.
Evidence - NONE!
