AWESOME!! thanks bro,
I nominate this for a sticky... It also shows every easy ways to get to a power source in the front!
Yea but u gotta get behind there, which means taking out the AC control box and who knows what elsewraith622 said:I was actualy thinking of just hard wiring my detector to the back of the cig lighter. Theres gotta be 2 wires (groud-black and live+red) there. you should prolly still run in thru an other fuse if your divice comes with one.
btw Thanks for the feed back.![]()
That my be true in regards to radar... but if they are using laser you will need the detector lower. The reason for this is because they point the detector at the headlights/license plate in order to get a reading.GASPowered said:The higher the detector is mounted the earlier the warning.
I took this route--just for a bit of clarification, I used the pink and black wire on the other plug. I wanted to maintain the ability to pop off the little map light/roof control panel.GASPowered said:I mounted my radar detector in the corner of the windshield where the oil change sticker usually goes. The higher the detector is mounted the earlier the warning. To hardwire it I simply tucked the wire in the headliner until I got to the moonroof controls and I spliced into the black wire that is part of the big molex connector. The ground is just connected to one of the metal screws that are in there. That black wire has power only with ignition so I don't have to worry about turning it on or off. I'm not sure if that wire is available without the moonroof. Just another option.
New dash kit??spicedham said:With the new dash kit out, has anyone thought of sticking the radar detector where the old LCD used to be (instead of installing the extra pocket)?
