I have a 12v accessory that powers on/off on the 12V ACC currently. I'd like to figure out a way to make it work differently, however:
When the car is turned on, the device does NOT turn on.
When I press a button AND the car is on, the device turns on
When I turn off the car, the device turns off.
... A simple toggle (on/off) switch wouldn't work, as I want to be able to turn the device on with the car started, but if I turn off the car and turn it back on, then the device shouldn't power up. With my limited knowledge, it seems I'd need to use a momentary switch/button, and a relay that provides power to itself. So, if I press the button, it activates the relay, and then the relay, once latched, keeps itself latched. ie:
12v ACC -> button (normal off) -> diode -> relay magnet
12v ACC -> relay latched -> diode -> relay magnet
12v ACC -> relay latched -> device
Does that make sense? Would it work? Can one of you 12v guru's explain what I'd need to do this and how I'd go about doing it?
Thanks
Gary
Thanks
Gary
