41 - 45 of 45 Posts
I just did this and I have stock low beams. I agree, HID's would look a lot better. I'm looking online for an HID set (most likely going with 5000k 35w set). Any recommendations?
I bought my 35 watt 5,000K HID setup from www.sharphid.com. I had a pretty good experience with them. I got the DDM Slims. There are a few places that are pretty reputable for HID's out there though.
[quote author=chrislitz link=topic=170855.msg4231212#msg4231212 date=1337441743]
I did the same, except I ended up getting the 6,000K HID's. I may end up picking up 5,000K's so that I get a better match with my LED's and such.
Also, side note. What I have discovered with playing with all the different external bulbs of the 2010 MS3 is that the 7443 is a dual filament bulb whereas it's brother (the 7440) is a single filament. Would this solution work just as well with a 7440 bulb that is colored yellow?
Also also, for those who may experience a problem with their headlights not being visible during the day (can be a "legal" problem when driving through construction zones or rainy days with just enough light), I would recommend LED switchbacks (I believe they are switchbacks) at the 7443 bulb size. These will glow white (approx 5,000k - 6,000k) when the turn signal is off and yellow when the turn signal / four ways are on. I'm trying these out to see how they look. One big fear I have is the turn signal brightness being too dim during the day.
Thank you for the thread! I used this thread and it helped me complete the task! thanks again!
Premium Member
Just did the parking light delete this morning and was done in 20 minutes. Thanks for the walk through!
41 - 45 of 45 Posts
