1 - 9 of 9 Posts
My 2006 mazda 3 has its own switch for the stock fog lights. Do you think I can tap the positive and ground from the fog lights??? Is there enough power?
my fogs lights only turn on if my headlights in the on position.
I tried tapping power from the parking light.. NOT enough power. WASTED 2hrs.
Is this possible???
To bypass your DRL’s which is what you are trying to do we sell a relay harness so you can bypass your stock headlight wiring, it is not recommended you tap your fog lights to run HID’s off of or your parking lights.
-Devin
Cuz he wants you to buy a harness haha.
You can tap the foglights if you want to do it that way but use a relay and get your power directly from the battery.
You can run wires from your fog light connectors to control your HIDs, then run wires from the low beam connectors to your fog lights. It has been done, and does work.
1 - 9 of 9 Posts
