so i did my rear pads today finally after putting it off for so long cuz of the cold weather.... pretty much everything that could go wrong went wrong. but i got everything on and my brakes are still super spongey... my pads were so worn the caliper pistons were pushed out all the way and seized. at one point in trying to free them we did try and compress them with a c-clamp (mistake 1)but i stopped after quickly realizing it wasnt budging....anyways after wrestling with them for forever i finally turned them in with pliers, got the pads all installed went to go pump my brakes and the pedal just went straight to the floor. after topping off my brake fluid resiviour and bleeding my brakes a little i got feeling back in the lower half of the pedal range.. but it still feels quite a bit weak when i first touch the pedal. do i need to bleed my brakes more? and can someone tell me if theres any sort of order i should do my wheels in or special procedures i should follow. also im pretty sure i didnt clip the pads on to the piston, (both pads seperated from the piston right when the calipers came off so i never saw it attached i guess) could this be why i have so much play?
