[quote author=sdemo45 link=topic=136347.msg2937909#msg2937909 date=1234681784]
If you wire to your maplights, the footwell LEDs will come on when the doors open. They wont come on when you turn on your map lights, considering turning them on is just completing a circuit inside the housing and doesn't control the power supply.
I wired my footwell LEDs to the maplights, and then another set to the ashtray light. If you wire to the ash tray light, they will only come on when your head lights are turned on.
If you want to pick and choose when they come on and when they dont, wire them to the cigarette lighter and put them on a switch.
so now knowing that the footwell leds will come on when the doors are open, what happens if i turn the map light switch to "off"? will the footwells still light up? or does the map light switch have to be "door" in order for the footwells to turn on? and will the footwells fade away like the map light does?
