1 - 8 of 8 Posts
i need some help in fine tuning my bump in the trunk.... i have a kenwood 1800watt Kac-9104D mono class D amp.
* Mono subwoofer amplifier
* RMS Power @ 2-Ohm: 900 watts x 1
* RMS Power @ 4-Ohm: 500 watts x 1
* 1-ohm stable (no power ratings available)
* CEA-2006 compliant
* Class D Amplifier Circuit
* Aluminum Die Cast Heat Sink
* Power MOS-FET Switching Power Supply
* Line Output Terminals (RCA) for Extension
* Gold Plated Power & Speaker Terminal
* Dual Mono Drive Ready
* Cooling Fan
* Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
* Built-in Infrasonic Filter 15/25Hz (18dB/oct)
* Bass boost (0-18 dB at 40 Hz)
* Subsonic filter (15/25 Hz, 18 dB/octave)
* Preamp-level inputs and outputs
* Dimensions: 13-13/16"W x 2-5/16"H x 9-3/8"D
im using: Rockford Fosgate - Punch 12" 4-Ohm Dual Subwoofers with Enclosure - Black/Silver
Warranty Terms - Parts
1 year
Warranty Terms - Labor
1 year
Product Height
16"
Product Width
34"
Product Weight
87 lbs.
Product Depth
17"
Woofer Size
12"
Woofer Material
Polypropylene
Magnet Size
62 oz.
Magnet Type
Double-stacked
Continuous Power Handling
250W
Peak Power handling
500W
Impedance
4 ohms
Number of Voice Coils
2
Efficiency
86dB
Frame Material
Die-cast aluminum
Recommended Installation Type
Vented
the amp isnt bridged that i know of. i bought both amp and sub brand new from best buy. i just need some help to make it sound good and bump hard!
Discussion Starter · #2 ·
any help?
not sure what you're asking for...or why they sold you a mono amp with two huge DVC subs...
but here is one way to wire it, if that's what you're asking.
I start with hi or low pass filters set near the frequencies the drivers are rated to handle and adjust from there by ear.
are you asking for advice on amp settings? if so, i personally would just turn it all to the lowest setting and play with it from there.
I agree. Just play a song that is the genre of music you listen to the most and fine tune the settings until you get the best sound. Then you can just use your HU equalizer to further fine-tune if you want.
alright i kinda played around with it today and it sounds good to me and it bumps. why are the too big for my amp???
hey, as long as it sounds good, that's what matters. I don't think it's too small, just thought a multi-channel amp would be used for multiple dvc subs.
mkay. yeah it sounds good. nice thump so far.
1 - 8 of 8 Posts
