1 - 3 of 3 Posts
So I just bought a Mazda3 hb about 1 month ago and i was driving my car into my house when the fence swung back and hit my car. I got paint all over it and i was able to remove it with rubbing compound,now my the paint is dull.............you can see some light white on the car...is their anyway of removing it? thanks
If you use a rubbing compound on paint then it will haze the surface. Especially if you did it by hand with a terry cloth.
In order to fix this you will need to use a polish intended to remove the haze. A light swirl removal, scratch remover, or fine polishing compound should help.
I would use a soft applicator that the product recommends and follow the directions carefully.
Rubbing compounds are generally the most aggressive so be careful when using this and don't apply excess pressure on the paint or it will surely get scratched and hazed "white".
The ideal solution would be a light swirl removing polish that's applied by machine, though I think it can be fixed by hand.
1 - 3 of 3 Posts
