Use this forum to discuss the HB's brakes: Specs Maintenance/Repair Aftermarket Thanks!
D dinu01 · Registered Joined Aug 7, 2003 · 4,849 Posts Discussion Starter • #1 • Sep 6, 2003 Use this forum to discuss the HB's brakes: Specs Maintenance/Repair Aftermarket Thanks!
atl · Registered Joined Aug 19, 2003 · 4,686 Posts #2 • Sep 24, 2003 I'm guessing that the Hatchback will use 4 disc brakes like the Protege5 wagon.
M mazda_gremlyn · Registered Joined Oct 14, 2003 · 94 Posts #3 • Oct 15, 2003 would make sense, standard abs you think?
D dinu01 · Registered Joined Aug 7, 2003 · 4,849 Posts Discussion Starter • #4 • Oct 15, 2003 Standard ABS on the top trims in Canada without a doubt (s in the US and GT in Canada, like with the Protege ES now).
S schulkw · Registered Joined Aug 16, 2003 · 984 Posts #5 • Oct 15, 2003 I hope ABS is standard on US models.
M mz6zoomzoom · Registered Joined Jul 30, 2003 · 14,337 Posts #6 • Oct 15, 2003 ABS is not standard on the 6, so I doubt it will be on the 3.... but then, the 3 has HID and Nav and the 6 doesn't have those, so who knows.
J jay · Registered Joined Oct 13, 2003 · 70 Posts #7 • Oct 22, 2003 U.S. specs: 4-door i - 10.9" front (ventilated discs), 10.4" rears (solid discs) 4-door s, 5-door s - 11.8" front (ventilated discs), 11.0" rears (solid discs) all models are power assist with optional ABS and EBD
