First off, refer here for the first go round of install instructions and discussion - - -
http://www.mazda3forums.com/index.php?topic=67408.msg1182994#msg1182994
Then we start up with another look at the mounting proceedure:
1. Tape and measure to the center. I erred and ended up about a 1/4 inch low - should be just above the line (reason to follow) -
2. I used a 1 1/2 inch hole saw. I went low to avoid the dip at the top - - -
3. The dome on the back of the display drops into the hole. Using a straight bracket, I was able to angle the display upward to make it easer to view - - -
4. Unfortunately, when you angle it up, it drops the unit. This is where the extra 1/4 inch would have come in handy - - -
5. Finished product looks good, but from the driver's seat the heat control is a little obscured. Fortunately, I usually keep it on auto. - - -
Questions for anyone that has one of these - - -
a. Have you found a way to play ALL of an artist's albums? So far it's select and play one at a time.
b. Have you found a way for it not to come on automatically with the key?
Thanks and enjoy!
Thanks and enjoy!
