I wanted to share this since I haven't seen anything about it on the forum. Seems like a nice alternative to the Dashhawk.
http://www.youtube.com/watch?v=aDn4n1VNM3w
• Up to 53 Items possible
• 3.5” TFT color touch screen
• ISO 14230, CAN, Non OBD
• 3-way display direction
• 6 read-out styles:
Digital, Bar meter, Needle meter,
Circle bar, Graph, Chart
• 5 display patterns:
Couple, Tandem, Lord/Tenant,
Couple/3 Fold, 6 Fold
• DTC – Diagnostic Trouble Code
Reading & Resetting (depending on vehicle.)
• 15 minute dataloging & playback
• English or Japanese language
• Metric or SAE measurements
• Eco-drive, Fuel Economy, Power estimators
• GReddy v-manage, f-manage compatible
• External Signal monitoring possibilities
• Programmable Warning Alarms (visual/audio)
• Programmable Max/Min Scales
• Peak Hold Memory (LO / HI)
• Selectable background patterns
• Day/Night settings
• Size 75mm x 107mm x d16mm
http://greddy.com/img/PHP/products/pdf/1383.pdf
Hooks up via OBDII port and powers with cigarette lighter.
http://www.greddy.com/featured/InfoTouchVol1.pdf
Has been confirmed to work on Mazdaspeed 3 (07-09) and display the following:
Tacho, Speed, Ignition Timing, Throttle, Throttle %, Water, In Temp, Intake manifold pressure (I assume that's boost), Airflow, Airflow%, Injector, Injector%, Power, Trip,
E Instant, E Average, E Total (I'm assuming E= fuel economy), E Section, Fuel Total, Fuel Cost, S Term FT,L Term FT, O2 V 2, Battery, Outside Temp, DTC, DTC Clear
