1 - 20 of 196 Posts
Hey folks, here's another group buy brought to you buy​
After the success of the last group buy for Vibrant headers and exhaust,
Crossover Auto is back again this time offering gauges by Prosport.
The gauges come in 3 color options:
Amber/White
Blue/White
WRX Green/White
Click here for demo video
Available Gauges:
Exhaust Gas Temperature
Using a 270˚ sweep movement for accuracy, now you can easily learn the
Exaust temperature & how your modifications will affect the engine performance.
With this gauge you can now tune your vehicle for peak performance.
(0-2500˚ F includes K type Probe/Sender, Mounting Hardware and Instructions)​
Mechanical Boost Gauge
If your vehicle is supercharged or turbocharged then this gauge is simply a must have.
For peak performance you need to know how much boost you are making at maximum RPM's.
Now you can track your peak boost as you modify your ride!
(-30 to +30 PSI includes Mounting hardware, Tubing Kit and Instructions)​
Electrical Boost Gauge
*This Electrical Boost Gauge will perform the Opening Ceremony/Pointer sweep, on Start-up. *
(-30 to +30 PSI includes Mounting hardware, Tubing Kit, Electrical sender and Instructions)​
Electrical Oil Pressure
Don't trust your factory gauge for important monitoring of engine functions.
By the time your factory idiot light comes on the damage is already done.
Monitor you engine functions with one quick glance and notice any problems before it is catastrophic.
(0-110 PSI includes Sender, Mounting hardware and Instructions)​
Electrical Oil Temperature
Powered by a rugged Movement and utilizing only top grade sending units these 270˚
full sweep electrical gauges are durable, reliable, safe & easy to install.
Monitor your engine temperature with more precision. Keep hazardous fluids out of the
passenger compartment.
(100˚-320˚F includes 1/8 NPT Sender, Mounting hardware and Instructions)​
Electrical Water Temperature
Powered by a rugged Movements and utilizing only top grade sending units these 270˚
full sweep electrical gauges are durable, reliable, safe & easy to install. Monitor your engine
(110˚-320˚F includes Sender, Mounting hardware and Instructions)​
Electric Voltmeter
In Dash Mounted 52 mm Tachometer.
0-8,000 RPM display
Finally a Tachometer to mount in your dash or mounting pod.​
Air/Fuel Ratio Gauge
Analog Air Fuel Ratio Gauge
Monitors your A/F ratio in real time.
This gauge also incorporates our opening ceremony/needle sweep
each time the vehicle is started.
Fuel Pressure Gauge
Once again, you asked and we delivered! Now you can monitor your
Fuel Pressure with the same Quality and look as our other gauges.
0-110 psi scale with full 270 degree LED display. This Electric Fuel Pressure
gauge will perform the pointer sweep on start-up!
(includes mounting hardware, Fuel Pressure Sender, quick connect pigtail wiring,
instructions, visor/hood & decal.)​
Digital Gauges
Digital Tachometer
A considerable amount of time went into developing the look of this digital tachometer.
The result is what you see here. A harmonious marriage of a high contrast tinted lens
with fluorescent digital readout achieves excellent daytime readability without blinding you at night.
When turned off this gauge is blacked out. This Digital gauge is one of the few
4 digit readouts on the market. Adjustable to 4, 6 or 8 cylinders. This high tech gauge is
even wired so that you can hook it up to your headlight to automatically dim the gauge
when the lights are turned on.
(Includes Mounting hardware and Instructions)
Digital Air/Fuel & Voltmeter Gauge
This is the first of one of the coolest product lines we are developing. This digital
gauge is like having two gauges in one. We started with a standard Air Fuel Gauge
and instead of wasting the valuable real estate in the center of the gauge with our logo
we utilized that space to display the A/F & Volts Digitally. It will display Air/Fuel ratio
around the outside while digitally displaying either A/F or volts.
Don't be left in the dust as Prosport continues to set the trend. This gauge also
ncorporates our opening ceremony/Self check each time the vehicle is started.
Check out the Demo page to watch it work.
(Includes Mounting Hardware and Instructions)​
******Premium Series - Available in Amber/White only******
52 mm (2") Stepper Motor Driven 270˚LED Display.
These are fully programmable to allow you to set the warning feature to
either beep or change color (or both) once the gauge reaches your pre-set limit.
270˚ dial sweep provides quick one glance accuracy. Track tested and race proven
these gauges use precision electric senders to keep hazardous fluids out of the passenger compartment.
All of our Premium Series gauges perform a dramatic opening ceremony with a
full pointer sweep each time the vehicle is turned on AND Off.
These are very easy to use, all programming is done from the front push button!
Wire up the first gauge for power and daisy chain the power to each gauge as needed!
As only Prosport would do, the Daisy chain power leads come with them! Nothing more to buy.
Click here for opening ceremony demo.
Click here for closing ceremony demo.
Electrical Boost
Electrical Oil Pressure Gauge
Water Temperature Gauge
Exhaust Gas Temperature Gauge
Electric Voltmeter Gauge
Fuel Pressure Gauge
[hr]
Sorry for the long post but I wanted to get all the information in one spot.
Pricing is as follows:
Standard:
Exhaust Gas Temperature - $80.10
Mechanical Boost Gauge - $33.30
Electrical Boost Gauge - $49.05
Electrical Oil Pressure - $34.20
Electrical Oil Temperature - $34.20
Electrical Water Temperature - $34.20
Electric Voltmeter - $32.40
Tachometer - $34.20
Air/Fuel Ratio Gauge - $38.25
Fuel Pressure Gauge - $40.05
Digital:
Digital Tachometer - $40.46
Digital Air/Fuel & Voltmeter Gauge - $49.05
Premium:
Electrical Boost - $71.55
Electrical Oil Pressure Gauge - $89.10
Water Temperature Gauge - $63.00
Exhaust Gas Temperature Gauge - $101.70
Electric Voltmeter Gauge - $61.20
Fuel Pressure Gauge - $92.70
Electrical Oil Temperature - $62.10
Tachometer - $62.10
Other:
Pro Shift Light - $44.96
Oil Filter Adapter Plate - $35.10
If you have any questions, please post or pm me.
When replying, please specify which gauge you want(standard, digital, or premium) along with color(amber, blue, green).
Not all gauges are pictured, so please check www.prosportgauges.com. All prices are 10% off their listed price. Shipping is $15 to continental US.
This group buy closes on 04/30/07 at which point payment should be made by 05/01/07.
Discussion Starter · #2 ·
Re: GI: Prosport Gauges brought to you by CrossoverAuto.com
1. the415 - Premium: EGT, Oil Temp, Oil Pressure, Voltmeter, Boost
2. aviateur - EGT, Oil Pressure, Oil Temp
3. Krystm - Electric: Boost, Voltmeter
4. Nutari - Electric: Boost
5. eurotuner - Pro Shift Light
6. mazdamn02 - Electric Boost Gauge
7. t-dogg - Mechanical: Boost, Air/Fuel; Digital: Tachometer
8. wbmazda3 - Premium: Boost
9. pandastew - Digital: A/F w/Volt; Standard: Oil Pressure; Other: Oil Sandwich
I'm thinking EGT, Oil Pressure and Oil Temp. Not sure if I'll go with the premiums or not.
Are there any instructions on the installs for these three types of gauges?
Jeff
yes, they all come with instructions.
I would be interested in the Elec. Volts and Boost. I don't know about premium ethier till some prices are posted.
EDIT: I know the Volt won't but can/will the boost meter void my warranty?
gauges can't void your warranty unless you do something completely retarded when installling which i can't even fathom how you could screw it up.
should have prices by monday.
[quote author=the415 link=topic=73341.msg1303284#msg1303284 date=1175366954]
I know they come w/ instructions, but I'm wondering if there are any howtos posted here or elsewhere on the net.
I've heard other people talk about an oil pressure plate that requires the spin-on oil filter conversion kit in order to get readings for the Oil temp and pressure.
[quote author=aviateur link=topic=73341.msg1303301#msg1303301 date=1175368138]
i know sok07 has done it. here's some quote text from his GB for the gauge panel.
[quote author=sok07 link=topic=72897.msg1298074#msg1298074 date=1175135064]
We finished hooking up the oil pressure sender and oil temp sensor. I used the sandwich plate (3/4"-16) and the 2.3L -> 2.0L spin-on conversion kit. Again, if you are going w/ the sandwich adapter and conversion kit route....get the 3/4"-16 adapter do not get the M20. 3/4"-16 is the thread size for the 2.0L spin on filter. Overall the sandwich plate and spin-on filter is about 3/4" longer than the cartridge assembly. This places the bottom of the filter just a hair above the plastic splash guard. It's a bit low but about 1" higher than the bottom of the oil pan, I opted to leave it this way rather than purchase a series of elbow and t-fittings to screw into the stock oil pressure sensor hole.
[quote author=sok07 link=topic=72897.msg1298908#msg1298908 date=1175184064]
Since you already have a spin-on filter...all you will need is a 3/4"-16 Oil Filter sandwich plate adapter and the gauges. I went w/ electrical prosport oil pressure and temp gauges and the standard voltmeter gauge.
If you need website links to buy the stuff or just want to inquire about the oil sender/sensor installation process, just let me know and I'll pm you.
how would you hook up the oil pressure or temp sensor, since we dont have the spin on filter, i know you can change it to the spin on filter, but there was talk about the adapter plate not being the correct size.
you can buy a kit to change it.
Discussion Starter · #14 ·
no, you must supply your own pod.
as for oil temp and pressure, you'll need an oil sandwich. for the 2.3's you'll also need a spin-on filter conversion from the 2.0. you can find more info about that in the modification section.
i'm using the glowshift oil sandwich. Product Number: GS-OC01 since i'll need oil lines for the turbo.
prosport carries a filter sandwich and i will ask about pricing on those as well.
415 i think you should also put the shiftlight in here, it is a digital RPM and precisse shiftlight.
LC got one, i saw it and it is really good.
[quote author=the415 link=topic=73341.msg1303845#msg1303845 date=1175389743]
415. Why isn't it possible to tap into the stock sending unit ("T") for pressure and use the oil drain plug (adapter) for temp?
Discussion Starter · #18 ·
you most certainly can do that. i'd rather not since it's not easily reversible. didn't mean to sound like the oil sandwich is the only way to do that. but you are correct, that method will work if you prefer.
[quote author=Freddyboi link=topic=73341.msg1304265#msg1304265 date=1175405975]
i read up on the filter sandwich adapter thing, but the thing that was brought up with that the sandwich piece had a different threading.
The reason the conversion kit needs a 3/4"-16 adapter is because our filter setup (both cartridge and spin-on) for our engine is sourced from Ford. I initially purchased the M20 adapter and upon mocking up the setup, it didn't work. I then pulled out my vernier caliper and measured the diameter of the oil filter thread = 3/4". Exhanged the adapter plate for a 3/4"-16, which works.
I'll be interested in this if the price is right...
1 - 20 of 196 Posts
