1 - 20 of 44 Posts
Okay, so I have been getting a huge request for these. So i spoke with one of the companys i work with and I get a Harden rubber verision for us, that would be better than the OEM ones.
What would you guys think?
Here is a pic of them. The price would be around $130 shipped
we would just need 20 commited buyers and they'll take 1-2 weeks to be made
They will ONLY fit the normal MZ3
Re: GI; Front Lower Control Arm Bushings
I would be interested.
[quote author=ShaleZoom3 link=topic=134503.msg2891476#msg2891476 date=1232998829]
Unless your control arms are binding or squeaking, then there is really no point in swapping out the bushings. However, if you're rebuilding your front suspension, then by all means go for it.
[quote author=bicycle_wreck link=topic=134503.msg2896673#msg2896673 date=1233182560]
I have over 80k+ on the car...I have a whole lot of squeaking going on.
[quote author=ShaleZoom3 link=topic=134503.msg2896685#msg2896685 date=1233182731]
Might as well rebuild the control arms then...
[quote author=bicycle_wreck link=topic=134503.msg2896753#msg2896753 date=1233185129]
Certainly a route I may go.
[quote author=AlpineFD link=topic=134503.msg2901536#msg2901536 date=1233358484]
put me down for a set ! This is for a total of 4 bushing correct? (2 per side)
How hard is this compare to stock ones? Can they make delrin bushings?
yes, it'll be all 4. These will be a upgrade compared to the stock ones.
wheel hop.
bottom line i would be very interested in these, would you need a press to install these on the factory control arms or is this like a simple bolt on type of thing. because if thats the case id be all over it and I now dozens if not many more would be as well
[quote author=budgy link=topic=134503.msg2906688#msg2906688 date=1233606936]
wheel hop.
No need for a press, that why I also like them.
for $100 bones i am most deffinatly in. i am amping up my suspension in every way i can without lowering the car and i have been searching high and low for bushings........blows my mind that they dont make bushings for this car.
you should see if you can slightly off set the larger bushing to increase caster. what is the stock caster setting OEM? it may benefit from more caster.
these will work with both Speed 3's and MZ3's? I will pass on the good word to a few others if they havent seen this yet, if this gets the go ahead consider me in.
Discussion Starter · #14 ·
[quote author=budgy link=topic=134503.msg2907048#msg2907048 date=1233614905]
They should fit both, but I will check the part numbers to make sure
And this will eliminate wheelhop with no increase vibrations or noises? I'm interested...
Discussion Starter · #17 ·
[quote author=ryukensfj link=topic=134503.msg2907165#msg2907165 date=1233617230]
They will help, there's not just one solution to eliminating wheel hop. No extra noise or vibs
[quote author=darkstarmotorsports link=topic=134503.msg2907185#msg2907185 date=1233617630]
IC... You gotta sponsor me already!
1 - 20 of 44 Posts
