1 - 10 of 10 Posts
got a question here.
currently, I own 07 mazda 3 S GT and the gas level reads very funny when it is cold out. For example, I had less than a full tank and it reads full most of the time. Sometimes, when car warms up, it goes down to the level; however, most of the time it does not do it.
This is not normal is it?
Plus, the dealer told me that if there is not any problem, I still have to pay them looking at it. is this right?
I'm 99.9% sure that there is something wrong with it.
How much of a fluctuation are you talking about?
the dealership should look at it for free if its under warranty....If a dealer does that...I would take it to another dealer.
Discussion Starter #4
[quote author=GT1 link=topic=72390.msg1276750#msg1276750 date=1174331422]
no matter what I have, it reads above full when it is cold out there. Even if I have only about 3 marks from the bottom, it reads above full.
[quote author=wychoi36 link=topic=72390.msg1276788#msg1276788 date=1174332095]
That's definitely not normal.
There is no good reason why the dealer shouldn't fix it under warranty.
Not normal. It should never cost anything for a dealer to look at your car under warranty if you suspect a problem.
Dealer has to replicate the problem so make sure you take it there on a COLD day when you think the problem will occur.
If you take it on a hot day when there's no problem of course the dealer will tell you nothing is wrong with it. heh
Discussion Starter #8
problem found on gas pump(?). part will be replaced under warranty and got loaner as well from the other dealer. Thankx for the help
They said it is a common problem.
gas pump...you mean fuel pump? just trying to clarify.
Discussion Starter #10
[quote author=ShaleZoom3 link=topic=72390.msg1284163#msg1284163 date=1174585567]
yes, i meant to say fuel pump lol sry about that
1 - 10 of 10 Posts
