When I was just about home after going out bowling this evening, I noticed a brief problem. At one point when I took my foot off the gas, my car slowed down suddenly, not to a stop, but enough to notice a jerking movement. My foot was off the brake the entire time. Obviously the car is supposed to slow down slightly if you don't have your foot on either pedal, but it should not suddenly slow down like it did. This continued to repeat itself till finally I pulled into a parking lot. I put the car in reserve then back into drive. I drove around the parking lot a bit and it seemed to drive normally. I then drove the rest of the way home (which was only about 2 blocks away), and it still felt normal.
Is this a potential fuel line problem? It is only about 10 degrees outside, so the cold may be the culprit. I don't plan on taking it to the garage unless this happens again. What do you think?
