1 - 4 of 4 Posts
I have a several r/c vehicles, all basically brand new and a carerra slot car track that I am needing to get rid of and willing to give someone a fantastic deal on.
First is a Duratrax Evader that has had one battery through it to break in the brushes, the motor has never even accelerated under load! It's stock with a forward/reverse ESC, two sets of wheels and tires, and radio. This is a RTR truck. I am also selling the batteries and charger with it. The charger is also brand new and is capable of charging nicd,nimh,li-po,li-ion,life batteries. It also comes with 3- 3000maH 6 cell nimh batteries.
Asking 235.00 shipped! The batteries and charger alone cost that much.
Second is a Losi Mini-T RTR with one run under and a brand new Mamba 6800 brushless motor and speed control. The brushless setup alone is about 130. This truck also comes with two sets of wheels and tires, the second set being a sand setup.
I will sell both the brushless setup and truck for 185.00 Shipped to the lower 48.
Next is a Aquacraft Miss Vegas unlimited hydroplane. This was broken in propperly and only has one tank on it since break in. This thing will FLY! It will do an honest 40mph which some of you know on water that's pretty quick. It's powered by an .18 water cooler OS produced motor. The bad: when I recieved it UPS had dropped the box and caused some fiberglass damage. The damage has been completely sealed by a hard/quick setting apoxy and doesn't take on water. If you are better at fiberglass work than I am it won't be anything at all to fix properly.
RTR with fuel bottle,older glow starter, and extra glow plugs Asking 235.00 shipped. Insurance is a must and is included in the asking price.
Video!
http://smg.photobucket.com/albums/v289/MidwestRacer/?action=view&current=DSCF3270.flv
Finally is a Carerra 1/32 scale Formula 1 slot car set. This set includes risers for the track to be setup in a figure 8, two F1 cars, controllers, powersupply, corner gaurds, and everything else that was included in the set. Also comes with two track accessory packs. Like everything else this has seen very very limited use, just twice as a matter of fact. The track is also capable of running 1/24 scale cars.
Asking 215.00 shipped
asking prices listed for each item above.
Re: FS: Two RC trucks
With a li-po or li-ion battery and correct gearing, 50mph is definately not out of the question for the mini-t. They have been clocked as high as 70ish with the correct combination of batteries and gears.
The duratrax should see 20-25 on a stock setup with a 3000mah nimh battery. If you want to keep it cheap you could pick up an orion 12x3 motor and a duratrax sprint speed control and see around 40mph, although it's no match for a brushless system.
1 - 4 of 4 Posts
