1 - 5 of 5 Posts
FS items - All cables/connections included as well.
The List - Pictures will Follow this Post.
-1 closed bandpass box with plexi-glass center. $35 In very good condition. Zero scuffs or tears.
-2 12 inch audiobahn high excursion Subwoofers $80 each, retail is $199 each. In excellent condition, like new. Product Description: Audiobahn performance-enhancing High Excursion Subwoofer, the AW1200V features design elements that intelligently increase the woofer’s overall efficiency. Capable of handling 700 watts RMS, the AW1200V offers not only power but increased durability in various applications.
The AW1200V High Excursion Subwoofer features a tall, narrow surround, further increasing cone surface area and giving way to more air displacement. “This woofer’s surround opens the door for a more controlled linear excursion,” says Daniel Jones, Product Development Manager and Designer of Audiobahn products. “When the user pushes this woofer to the limit, the surround maintains its hefty durability and having more cone surface area further increases air pressure.” With an efficiency rating of 94.65dB, the dual 4-ohm AW1200V also features a high gloss cone manufactured from high-strength carbon composite, giving the component a radiant overall look.
-1 Kicker XS50 competition amplifier. $225, value $400. Brings back the glory days when the original Kicker "cheater" amps surreptitiously ruled SPL contests. Rated at first glance at a mere 25 watts x 2 at 4 ohms, this monster's massive power supply will churn out up to 300 watts RMS per channel at lower impedances!
The XS50 is stable down to 1/2-ohm stereo or 1-ohm mono, so you can design your multi-speaker system to play at extreme levels without fear of distortion or overheating. But even if you're not a competitor, this amp's pure versatility makes it a superb investment, especially at this special purchase price! Whatever the task — amplifying tweeters, speakers, or subs — you can count on the invincible XS50 to pump out ultra-clean power.
The amplifier is equipped with the ZRX active crossover module (80 Hz low-pass, 100 Hz high-pass, 12 dB/octave) so you can adjust frequency output for specific applications. Dark gray removable endcaps hide all speaker and power connections for a clean-looking installation. And rest assured that this amp was individually tested, not sampled from a larger batch of its brethren — its unique quality assurance certificate is proof that it lives up to Kicker's tough standards.
Note: This amp uses three 30-amp fuses. If you use a standard 4-gauge wiring kit, you'll also have to purchase a 90-amp fuse and fuse holder. (See "Wiring Recommendations" under the Detailed Info tab.)
Details:
•stereo or bridged mono output
•Tri-way capable (Tri-Way crossover required)
•frequency response 10-28,000 Hz
•25 watts RMS x 2 at 4 ohms
•75 watts RMS x 2 at 2 ohms
•150 watts RMS x 2 at 1 ohm
•300 watts RMS x 2 at 1/2 ohm
•150 watts RMS x 1 at 4 ohms in bridged mode
•300 watts RMS x 1 at 2 ohms
•600 watts RMS x 1 at 1 ohm
•MOSFET power supply
•module docking port with 2-way active crossover (80 Hz low-pass, 100 Hz high-pass, 12 dB/octave)
•removable dark gray endcaps
•discrete output transistors
•gold-plated, custom-tooled speaker and power connectors
•speaker connectors accept up to 8-gauge wire
•requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
•silent turn-on/off circuitry
•RCA outputs send full-range signal to another amp
•21"W x 3-1/16"H x 10"D
Discussion Starter #2
Re: FS Stereo System- Not Stock
Bandpass Box Pictures
12 inch Audiobahn high excursion sub woofers
1st one
2nd one
back side
And the Kicker XS50 Competition Amplifier
Discussion Starter #5
[quote author=Canadian_LX link=topic=184206.msg3895912#msg3895912 date=1293924850]
That's some really old school equipment :shock:
Love the amp man, im surprised you're selling it.
Good luck with the sale!
I got it all brand new in 2005 (except the amp). So its just 6 years old now. I never strained it and I haven't had it in my car for 2 years. Its been sitting in my room. Time to get rid of it. And thanks.
1 - 5 of 5 Posts
