1 - 5 of 5 Posts
I'm selling a pair of JBL EON15P-1, these speakers are powered and are great PA/DJ speakers, pair this with some powered sub and your good to go, indoor halls this speakers kicks!, I'm asking $500 for the pair OBO, sorry but this is only for Norcal pick up since these are really heavy to be shipped out.
Specs:
Power Rating:180 W
Frequency Range:47 Hz - 18 kHz
(-10 dB)
Dimensions
(H x W x D):686 mm x 430 mm x 444 mm
(27 in x 17 in x 17.5 in)
Frequency Response:65 Hz - 16 kHz
(±3 dB)
Horz. Coverage:90° Nominal
(-6 dB)
Vert. Coverage:60º Nominal (-6 dB)
Rated Maximum SPL :127 dB, @ 1 m (3.3 ft)
Net Weight:21 kg (47 lb)
Features:
-15 in Differential Drive® low-frequency driver with neodymium magnet for light weight and reduced distortion.
-1 in (throat diameter) JBL compression driver with 1.75 in titanium diaphragm and ferrofluid cooling.
-Internally Bi-amplified - 130 W low frequency and 50 W hi-frequency (bi-amplified) - actual power delivered to the drivers.
-Balanced, Mic/Line switchable, XLR input.
-Loop-through XLR output. "Daisy-chain" additional EON speakers.
-90° x 60°(nominal) constant directivity horn.
-Thermomaster® Total Thermal Management System®. A single piece, cast-aluminum baffle integrates the woofer frame, horn, and amplifier heat sink. Air movement in the finned ports dissipates heat - no internal or external cooling fans are required.
-Rugged, lightweight (47 lb), co-polymer enclosure.
-Integral 35 mm pole mount receptacle with securing thumbscrew.
-Multi-angle enclosure for front of house or stage monitor application.
-Integral attachment points for optional JBL and third-party mounting brackets
[quote author=trdsw link=topic=201461.msg4158642#msg4158642 date=1323408057]
bump for a Great seller!
[/quote]thnxs man!, how you been?
Im doing well. you know if you sell you r DJ speakers you gotta change your name to to just Chris721 right?!?!
Discussion Starter #5
[quote author=trdsw link=topic=201461.msg4159825#msg4159825 date=1323719335]
[/quote] :lol:
1 - 5 of 5 Posts
