Hi-
I have an 07 3s touring sedan and I want to replace the front speakers. I plan on installing a Pioneer Premiere 780mp as well. I want to keep the stock front tweeters as is, and use them with the replacement speakers, so it is important that the stock tweets and replacement speaker compliment each other so that I don't have a huge bump at 6khz for example(although I will have graphic EQ ability). I also plan on installing a sub, so more than likely I will be engaging a HP filter on the fronts probably at around 85 hz, so bass response from the fronts is not crucial. I am also looking for a speaker that will fit perfectly into the existing speaker mounts so that I don't need to cut anything away etc... Last, I am not looking to spend an arm and a leg. I know it's a tall order but are there any audiphiles on this board that have done this?
Ideas?
One more thing, if anyone can point me to the specs for the stock speakers and tweeters(including crossover points used) it would be greatly appreciated.
Ideas?
