Okay folks,
This is one I've been wrestling with for a while now. Our '06 3 with 86k on the clock is developing a rhythmic front end noise (kind of a wub wub wub sound) and sometimes, at highway speeds, a very slight shimmy. It seems to get worse when turning, at least when turning right (like when going through a cloverleaf), and worsens on rough road surfaces but sometimes disappears entirely on smooth roads.
My first instinct was to think that a wheel was out of balance. A couple of weeks ago I switched my summer 17" wheels/tires to my set of 16" wheels and snow tires...and the noise persisted (though not the vibration as far as I can tell).
Next thought was wheel bearing(s). Normally they make a grinding noise when they start to go, and I'm not getting much by way of nasty sounds, but I do know that they can also make a rhythmic noise too. I put the front end up on the jack and checked each wheel; no play whatsoever when trying to rock the wheel at the 12 and 6 position.
I had the shocks/struts replaced all around about 6 months and 6,000 miles ago; for the fronts, the struts themselves, strut bearings and endlinks were replaced. Also replaced was the driver's side axle (due to a f*ck up on my part when trying to replace the front suspension myself). And about a year (and 20,000 miles) ago, I replaced the front brake pads and rotors, with no drama from them.
I'm at a loss as to what it could be. There are no obvious leaks underneath the car from broken bushings (though I do know that bushings can wear without leaking), and as best I can tell, the passenger-side motor mount hasn't failed (again). Can wheel bearings wear out like I've been experiencing, but not have any play in them? Any other things I can check/test before I haul the car into the shop? With just one front wheel off the ground (no room to put the car on jackstands in my tiny-ass garage, sadly), if I put it in neutral can I get the wheel to spin freely to check for noise?
Thanks guys!
Thanks guys!
