There is no camber or caster adjustment front or rear. Only thing that is adjustable is the toe. The big problem with making a camber/caster plate for the front is that the strut bearing, topmount, etc. is all one big assembly. You would need a new strut hat and then a spherical bearing in the plate. All that would be easier to do if you used coilovers due to the smaller diameter(which is standardized) of the top of the spring. Basically, there is no easy way of doing it unless you swapped out a bunch of stuff. The rear is simple, though, just get a new control arm to adjust the camber.
jetmech53, did you by any chance get the car alligned after lowering it. I lowered mine and it through the toe way off at all 4 corners. Improper toe will wear the tires faster than anything. I rolled a whole week(300+ miles) without an alignment and it wore the inner parts of the tires pretty well. Too much negative camber will wear the tires too, but not nearly as fast.
