[quote author=jdanielsg link=topic=66831.msg1147931#msg1147931 date=1168713888]
So I would focus on the 4 speakers in the car and tweeters.[/quote]
I honestly wouldn't even worry about the speakers in the rear doors. You don't have any rear speakers with your Electras, do you?
I wont buy Focal unless it is the Utopia Be line, I do not like the look of the other tweeters. Question is.. how would these fit on my door and where would the tweeters go etc... like do i have to get the grilles they sell on there and have the shop do some special cuting and mounting of the new grilles and like would these even fit in the door etc..
geewhizbang and I have a little differing opinion on this, but both agree that the install is key. The 6.5" midrange driver will be able to fit behind the factory door panely fairly easily. IMO- the best/easiest solution to the door install is
proper sound deadening in the front doors. A minimum of two layers of sound deadening on both the inside and outside door skin, and an acoustic foam solution inside the door and on the inside door skin as well. The baffle the woofer is mounted to should be a minimum of .5" thick and SOLID (this might require some fiberglass work as geewhizbang discussed).
and where would the tweeters go.... they look quite big. the Be r just speakers right? for the car line.. not like s sub woofer or anything...? I am not familiar with car audio at all.
The tweeter might be able to go into the factory location with some fabrication of a tweeter pod, or in the factory A-pillar(this location can work very well with Focal tweeters).
You will want a sub of some sort, but a nice 8" sub tucked into the jack well should suffice to cover the low-end and help cover a bit of the mid-bass the Focals lack.
If you're using VTL tubes to warm up the sound of the Electras, I would be willing to bet you'll be able to hear the difference between car amplifiers as well. Honestly, you're probably better off talking to wherever you'd buy the Focals from and see what they recommend (as long as you can trust them).
You obviously enjoy higher-end gear, and car audio for you will a compromise between the sound quality you're used to and cost (as it is for many). I used to have customers that had $10,000 speaker cables with a $2000 car audio system that put a smile on their face, and customers that had $500 home systems that were critical of every nuance of their $15,000 car audio system and rarely happy.
Try to find a shop that is willing to work with you and will allow you to try out different products to make you happy.
