Stock Wheel & Tire Info
All sizes:
  • Bolt Pattern - 5x114.3 (5x4.5)
  • Hub Bore - 67mm
  • Lug-nut pitch - 12mm 1.5 (M12x1.5)
2004-2006 OEM Mazda3 16-inch
Width - 6.5 inches
Offset - 52.5mm
Weight - 15.8lbs
Wheel+Tire - 39.4 lbs with Toyo Proxes 205/55-16
2007-2009 OEM Mazda3 16-inch
[needs to be verified]
Width - 6.5 inches
Offset - 52.5mm
Weight - 18.4lbs
2010+ OEM Mazda3 16-inch Steel Wheels w/ Hub Caps
(iSV and iSport)
Width - 6.5 inches
Offset - 50mm
Weight - Unknown
Wheel + Tire - Unknown with 205/55-16 All-Season Radial Tire
(iTouring)
Width - 6.5 inches
Offset - 50mm
Weight - 16lbs
Wheel+Tire - Unknown with 205/55-16 All-Season Radial Tires
2004-2006 OEM Mazda3 17-inch
Width - 6.5 inches
Offset - 52.5mm
Weight - Unknown
Wheel alone - 22lbs ( http://www.mazda3forums.com/index.php?topic=40877.0 ) or 19.4lbs ( http://www.mazda3forums.com/index.php?topic=32422.0 )
Wheel+tire - 43.4 lbs
Tire size - 205/50-17
2007-2009 OEM Mazda3 17-inch
Width - 6.5 inches
Offset - 52.5mm
Weight - Unknown
Wheel alone - 22.1lbs
(http://www.mazda3forums.com/index.php?topic=63234.0 )
Wheel+tire - 43.4 lbs with Goodyear RSA 205/50-17
2010+ OEM Mazda3 17-inch
Width - 7 inches
Offset - 52.5mm
Wheel Alone - 22lbs
Wheel+Tire - Unknown with Toyo Proxes All-Season Radials 205/50-17
2007-2009 OEM Mazdaspeed3 18-inch
Width - 7 inches
Offset - 52.5mm
Wheel Alone - Unknown
Wheel+Tire - Unknown with Bridgestone Potenza 215/45-18
2010+ OEM Mazdaspeed3 18-inch
Width - 7.5 inches
Offset - 52.5mm
Wheel Alone - 25lbs
Wheel+Tire - Unknown with 93Y Summer 225/40-18
2014+ OEM Mazda3 18-inch
Width - 7.0 inches
Offset - 50mm
Wheel+Tire - Unknown with All Season Radial 215/45-18
2014+ OEM Mazda3i 16-inch
Width - 6.5 inches
Offset - 50mm
Wheel+Tire - Unknown with All Season Radial 205/60-16
Discussion Starter #2
Re: FAQ: Stock Wheel/Tire Info & Aftermarket Wheel Essentials (Updated 04/19/10)
Tire Upgrade
215/45/17 Tires should fit on stock 17x6.5" rims. (1.8% "too fast" reading on the speedometer.)
225/45/17 Tires are not recommended for anything less than a 7" rim. (So they are not recommended for the stock rims.)
Tire size Calculator: http://miata.net/garage/tirecalc.html
Tire sizes that maintain same outer diameter of stock tires +/- 0.5%:
  • 225/45-17
    225/40-18
    225/35-19
    215/30-20[/list]
    Wheel Upgrade
    Wheel offset calculator: http://marksink.com/tire_wheel_offset/offset.html
    See also (if you're Excel literate): http://jcbyrd24.fastmail.fm/ (Special thanks to JCByrd24 for this one.)
    GENERALLY RECOMMENDED OFFSETS: (Please PM corrections)
    • 7.0" - 40,42,45mm
      7.5" - 45,48mm
      8.0" - 50mm (RX-8 wheels)
    Offset to maintain same inner edge-strut distance:
    These offsets are not endorsed and are provided for reference.
  • 6.5" - 52.5mm
    7.0" - 46.5mm
    7.5" - 39.5mm
    8.0" - 34.5mm[/list]
    For reference, specific offset/width/tire set-ups that have been successfully utilized by forum members are listed below. There is no guarantee
    expressed or implied that these set-ups will work with your car, your tires, your passengers, your suspension mods, or your potholes.
    From original FAQ
  • 17" x 7.0" ~ 45 ~ 215/45/17 works.
    17" x 7.0" ~ 45 ~ 225/45/17 works.
    18" x 7.5" ~ 42 ~ 225/40/18 ( http://www.mazda3forums.com/index.php?topic=28200.0 )[/list]
    As seen in threads (with links)
  • 17" x 7.0" ~ ?? ~ 225/45/17 ( http://www.mazda3forums.com/index.php?topic=32433.0 ) Mazda6 Wheels
    17" x 7.0" ~ 55 ~ 205/45/17 ( http://www.mazda3forums.com/index.php?topic=18521.0 ) New Miata Wheels
    17" x 7.0" ~ 55 ~ 225/45/17 ( http://www.mazda3forums.com/index.php?topic=34130.msg486573#msg486573 )
    17" x 7.0" ~ 50 ~ 205/50/17 ( http://www.mazda3forums.com/index.php?topic=33754.0 )
    18" x 7.5" ~ 45 ~ 225/40/18 ( http://www.mazda3forums.com/index.php?topic=22589.0 )
    18" x 7.5" ~ 47 ~ 225/40/18 ( http://www.mazda3forums.com/index.php?topic=37723.0 )[/list]
    Received via PM
  • 18" x 7.5" ~ 45 ~ 225/40/18 (Mk33)
    20" x 7.5" ~ 45 ~ 225/30/20 (Mk33)[/list]
    Please PM other known conformations that have been successful.
    (Include in PM if you're willing to have your forums name next to the sizes
    that have worked for you, knowing people may PM you if they're
    considering that size.)
    This thread is intended as an FAQ and will be updated as frequently as possible when information is sent via PM to LaraW.
    Thread Created: 2004 July 14th by M3-GT | Updated 2005 July 13th by EvilGenius
    Thread Updated: 2011 April 6th by LaraW
