I have had the amp for approximate 5 years, not a single issue with it. Subs are about 3 years old, also no issues. Enclosure I just got over the christmas holiday- subs do not fit in the correct way that is why they are inverted. Kinda pissed :x about that and also would rather downsize everything after thinking about it for a week now. If you are wondering how this gear gets treated, I baby my audio equipment and dont really turn it up enough to go deaf but if you know the JL line then you should know how well it performs. I have other systems in other cars for SPL, this one is just for SQ.
Dont really want to part with it but shit happens..... :shock:
475.00 shipped 48 US states takes it all, or 250/225 if want amp or subs/enclosure split. If you want to throw out some offers, ill consider them of course.
I will have to ship the subs loose but flipped so magnets would fit back in the box. Wrapped in foam so they wont bounce and tear up the enclosure.
If you really want to fix the enclosure, about .4" needs to be shaved out of the opening. I dont want to scratch it all up so ill leave it to the next owner to deal with. I have the tools just not the time.
Specifications---
10" W3V2D6 Series Subwoofer
RMS Power Handling: 300 Watts
Dual 6 Ohm Configuration - runs at 1.5 on 500/1 amplifier-
2-1/4", 4-Layer Voice Coil
Kapton Voice Coil Former
VRC Technology: Cools the Voice Coil
Elevated Frame Technology: Enhanced Cooling
Powder-Coated Silver Frame Finish
Dished Cone/Dust-Cap Design
Rubber Mounting Flange Gasket
Sealed Box Volume: 0.60 - 0.90 cu. ft.
Ported Box Volume: 1.0 - 1.5 cu. ft.
Top Mount Depth: 5-3/4"
Cutout Diameter: 9-1/8"
JL 500/1
http://mobile.jlaudio.com/pdfs/Slash_amps/500_1_MAN.pdf
Allen key terminals are not stripped out!
Enclosure
1.6 cuft airspace
Fiberglass with MDF bracing
Single chamber
Painted with 1 coat dark gunmetal metallic paint
As far as cosmetic, the enclosure was shipped NEW with a couple scratches , could use a real good coat of clear to make it shine.
Amp has a couple surface scratches but nothing too serious.
Subs are mint except for the back plates have oxidation from being inverted from a previous setup. The whole point for the new enclosure was to have them flush mounted and out of the way.....
Discussion Starter #2
***********SOLD**********
