I just spoke with my college combustion sciences professor. He has done significant research on direct injection engines at Univ of Texas. His work began several years ago on the J-spec engines that could not meet US emissions requirements. Then, they were using injection technology called "spray guided" direct injection which aimed the spray at the spark plug. Also there was "wall guided" which sprayed the piston and/or cylinder wall.
His research showed that spraying the fuel on any surface in the combustion chamber produced large amounts of particulate emissions. He is not totally familiar with the Mazda design but assumes they are using the now popular "air guided" injection (not sure what that implies). Still he said that if their system was not perfect and fuel was coming into contact with any surface, high particulate emissions would result. He also reinforced that they would not be using an overly rich mixture when not needed; only high load periods. Therefore, unless you're hard in the throttle all the time (me?...never), the sooty tailpipe is likely due to the injection method.
Anyways, somewhat trivial information, but I thought I would pass it on.
