ok. its like 6 30 and getting dark, i have my fogs mounted. and aftermarket harness through the firewall to my oem rocker switch.
what wire should i use to get power for my switch? should i tap a wire in the steering column? or can i use the wires on the dimmer switch. please help. got like an hour to finish this.
It kind of depends on when you want them on. Assuming of course you have a relay harness and you're just looking for a signal wire you could tap the cigarette lighter so the fogs will work when the car's on, or the ring around the lighter (or the ash tray light) if you want them with just the headlights.
