I am in the midst of swapping a 2010 Fusion 2.5 motor into my 2007 Mazda 3 2.3 . The original motor began running rough around 200,000 miles, and there are metal shavings in the oil pickup tube, so it was time.
I have both motors on stands and have removed the valve covers, oil pans, and crank pulleys.
My question is about the friction washer(s). Best I can tell, there was no such washer on my 2007 2.3. When I removed the pulley from the Ford 2.5 L a friction washer fell off onto the floor.
My question is whether this is the only washer that I need to replace? This would be between the pulley and the crankshaft. I have read parts diagrams from a 2010 Mazda workshop manual online showing another friction washer between the timing chain gear and oil pump gear, but I did not touch those.
Is it correct to just replace the one that fell out and leave the others alone?
Thanks so much in advance.
Yes. Just the one. For my 07 Mazda 3 2.3-2.5 swap, the Mazda parts man confirmed that you need only 1 as you said as the other is behind the cam gear remains untouched. L3H5-11-407 is the friction washer. LF01-11-406 is the torque to yield crank pulley bolt.
