If you go with a 55w all the way around you wont see an increase in lumens. Wattage for wattage filtered bulbs designed to produce white (by filtering yellow via blue glass) will reduce lumens a small %. Granted, you might not notice it but its a fact.
I would recommend 55w H11, 80w H7 and 80w 9005. With all three I would highly recommend a harness upgrade to handle the added power requirements. This will prolong bulb life and gurantee steady energy to the bulbs bypassing any weaker factory wiring and connectors. The harness is only used for the main and high beams, the fog lights are fine.
