So, I've been noticing an odd thing when I check my oil. The first time I read it, it shows a low oil level. Since I usually let it set overnight on a level surface, the level is clearly visible about 1/2 way between the max and min lines. But if I check it again right away, I get a different level that is a little above the max line. I can repeat the check again and get the same level - above max.
I got some ideas on this, but would like some help from others in the forum to do an science experiment and share your results. I want to see if this is something common to all MS3's or if it just my car.
1. After driving, park on a level surface and wait at least an hour. Don't check your oil before waiting!
2. Pull the dipstick straight out and read the level
3. Wipe the dipstick, put it back in, pull it out and read the level.
4. Repeat step 3 to get a 3rd reading.
Then post what the levels were for the 1st, 2nd, and 3rd readings. If you know for sure how much oil was put in at the last oil change, post that too.
