Re: devils own out put problem
You'll likely have to remove the nozzle to visually look for a spray ... if you teed into a vacuum line for boost trigger, use an air compressor to pump that up to your boost trigger point (14 psi or whatever). Otherwise, can you have the nozzle placed outside the hood somehow and go for a drive??
