I needed to make a plate to mount my amp to since I wanted to use the cargo hook brackets in the back so I went searching for something pretty strong and the right shape... Came across a nice 2 set of cutting boards at walmart, one of which is 11x14 which would just about fit perfectly.
I ran over to lowes (a few times as the design changed) and grabbed some 6x20 metric bolts (probably should have been 25 to be safe) and big fat washers to mount to the factory mount point thing... I also found some nylon offsets to lift the amp up so I could run wires underneath.
I ran all the wires Saturday back to the little light access panel in the back which I was lucky enough to be able to stick my hand into pretty easily. I dry fit the board in place and traced around where the handle was to cut a hole to run the wire out of, then cut out a little rectangle with my rotary tool. I then bolted the plate to the top, and screwed the bottom two into the plastic panes under the carpet. Small pilot holes made screwing the amp in a little easier. There is about an inch of cutting board overlap on the top and bottom but I think I can live with it.
You can see the handle on the side where the wires run out of which turned out pretty good.
The spacers add enough room to run cables underneath and add a little airflow.
It turns on when the car is on and off when it is off, so I at least got that part right... I will have to wait for brown santa to come to install my sub and see if the controls work...
